dragonrider
Member Username: dragonrider
Post Number: 4 Registered: 06-2005
| Posted on Monday, July 18, 2005 - 08:44 am: |
A friend has a P5. It has been overhauled, The Magneto rewired.Carb cleaned. But It will not start. Easy start wont work.Tried oil down S/Plug hole, Engine started. Ran a while stopped and wont start again. Any ideas anyone. Ps rewired my P66.to a single switch.all ok thanks to all who replied. |
Post Number: 244 Registered: 07-2002
| Posted on Monday, July 18, 2005 - 01:24 pm: |
Sounds like it may be low on compression, does it feel like it when pulling it over? It should have a good bounce when rocked against compression. If a two cycle has blow-by it kills the next intake stroke by filling the crankcase with exhaust. |
peterogborne
Post Number: 256 Registered: 09-2002
| Posted on Tuesday, July 19, 2005 - 07:56 am: |
My thoughts as well . Stuart Turners realy need good compression. When the engine was overhauled was note taken of the ring gap? Also the crankcase seals? I substitute synthetic seals to replace the original S/T ones. If new rings were fitted it certainly helps to remove the cylinder glaze.....with a hone. |
