Grey phantom 4
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Grey phantom 4 « Previous Next »
calvin parks
Username: calvin
Posted on Thursday, December 01, 2005 - 08:25 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am tyying to find the correct color for this engine...also some specs such as hp and displacement and parts availability...thanks
Lawrence T Wolfe
Username: larry_from_maryland
Post Number: 278
Posted on Thursday, December 01, 2005 - 01:07 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The phantom series was made in many differant size engines so you will have to provide more info for us to help on the spec.
calvin parks
Username: calvin
Posted on Friday, December 02, 2005 - 08:14 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This motor is a model 4-75 year unknown....it is now painted red and has a zenith carb and a 1-1 gear
Andrew Menkart
Moderator
Username: andrew
Post Number: 1268
Posted on Friday, December 02, 2005 - 04:00 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Graymarine model Four-75:
  • 4 cylinder
  • 3-7/16 x 4-3/8
  • 162 cu in
  • 75HP @ 3600RPM
  • 85HP @ 4000RPM
  • Weight Direct Drive: 540 lbs
  • Approx oil capacity: 7 qts
Additional info is in the Graymarine Handbook.
Lawrence T Wolfe
Post Number: 279
Posted on Friday, December 02, 2005 - 06:45 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Allso thats an F series continential engine.They were widely used in farm and construction equipment.
Bruce Hall
Username: bruce
Post Number: 296
Posted on Saturday, December 03, 2005 - 09:48 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Seems the Green used on GM Deisels is pretty darn close to the original green that Graymarine used.
No1SpeedSkiff
Posted on Friday, December 16, 2005 - 09:02 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
What is the prefix letter and serial number on the brass plate located either on the exhaust manifold or trans cover?
