Schebler mo. D carb
Old Marine Engine » Carburetors, Mixers, Vaporizors » Schebler mo. D carb « Previous Next »
outboard motor service
Username: outbrdmtrsvc
Posted on Wednesday, November 15, 2006 - 10:38 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a schebler mo.D carb in need of a needle valve. Does any one know of a source.I would love to hear this old St. Lawerence run.
George Coates
Username: george_iv
Post Number: 53
Posted on Wednesday, November 15, 2006 - 12:39 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Are you refering to the needle operated by the float or the mixture adjusting needle?
Posted on Wednesday, November 15, 2006 - 04:42 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thank you for replying George, I was refering to the needle operated by the float,mine was missing, all the other parts seems to be there. I did see that the popit valve at the air intake seems to be a little out of round and there is a gap under the valve to let air bypass it.
