Sea scout 91operating temperature?
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Sea scout 91operating temperature? « Previous Next »
Paul Spratt
Username: pspratt
Posted on Thursday, August 17, 2006 - 08:30 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
My temp gauge never moves from zero. I plan to replace what is necessary to get it functional, but any advise is appreciated. I have reasonable water flow through the engine but am paranoid about overheating. I am curious what temperature I should expect to see...previous owner doesn't remember.
Also, I understand that this engine dies after 15-20 min of full load running. It will apparently re-start without complaint, but it will continue to quit. Any thoughts?
CraigP
Posted on Tuesday, September 19, 2006 - 02:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
my 162 four cylinder never had a thermostat, the temp gauge only lifted off zero when it was about to skyrocket!
CP
JOHN DEBATES
Username: cam_gear
Posted on Wednesday, September 20, 2006 - 09:05 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
PAUL
THE TEMPERATURE RANGE ON A SEA SCOUT IS 140 TO 180 SET BY THE BY-PASS VALUE.
JOHN
