Bedford Diesel 330
Old Marine Engine » Timers, Magnetos, Ignition » Bedford Diesel 330 « Previous Next »
Debbie Rose
Username: roseagain
Posted on Wednesday, October 10, 2007 - 01:34 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
does anyone know the timing for 330 please or how to find out
Peter A Forbes
Username: listerdiesel
Post Number: 22
Posted on Monday, November 26, 2007 - 05:31 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Injection or valves?
The timing gears are all marked, there is an idler in there between the crankshaft and the other gears IIRC.
The injection pump is keyed to the drive shaft from the timing case (or compressor if yours has come out of a truck) so you should be OK there (there is a splined shaft on the DPA pump which has one spline missing, so it will only fit the socket in the engine the right way round.
The timing gears only match up once in every 180 turns of the crankshaft, or something in that order, so you need to get them set right.
Marks are punched dots, some had a small 'o' if my ageing memory serves me right. There will be two dots on one gear and one dot on the other matching gear.
The single dot has to fit between the other two It has been nearly 30 years since I worked on one at a Bedford dealer in Reigate, Surrey.
You do need to have the timing case cover off, which means the crankshaft pulley has to come off as well. Get a new seal for that and oil or grease it before refitting.
Peter
Vernon Smith
Posted on Wednesday, December 31, 2008 - 10:26 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Anyone know the max recommended rpm of a Bedford 330 (98hp) please? circa 1975. I have one in a 30 ft boat and I'm frightened of over-revving it.
Tks
Vernon Smith
Todd Vidgen
Username: todd_vidgen
Post Number: 108
Posted on Friday, January 02, 2009 - 09:48 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I'm looking at a cable driven tacho on my desk,
off a 330,right at this moment.
It red lines at 2500 rpm,but as the area from
2000 to 2500rpm is highlighted in white banding
I assume anything over 2000 rpm is stretching a
friendship.
Hope it helps ,Todd
