SOS - Help! Diesel Engine Advice |
palgrave
New member Username: palgrave
Post Number: 2 Registered: 07-2009
| Posted on Monday, July 06, 2009 - 04:27 pm: |
Can anyone help? I have a Sabb 8hp single cylinder diesel in a 14 foot river launch. I have fitted the engine with rubber engine mounts on the main engine brackets, and directly to the oak engine bed with the g/box mounts/brackets. Engine and shaft run well, but the engine has a lot of vibration! And I am concerned that it may damage the shaft (direct couple to the prop shaft). Can and should I fit the engine directly to the substantial oak frame to reduce the vibration? Would this reduce the vibration? Thanks |
boatbum
Member Username: boatbum
Post Number: 19 Registered: 05-2006
| Posted on Monday, July 06, 2009 - 05:19 pm: |
Single cylinder engines are notorious for vibration. Most boats were designed around an engine, if yours is original I would think the rails were designed for the engine. Try finding a throtle position that creates the least vibration and run her there. Most older engines were directly mounted to the bed frame. |
palgrave
Post Number: 3 Registered: 07-2009
| Posted on Monday, July 06, 2009 - 05:33 pm: |
Thanks for your feedback/advice. My boat had a S&T single cylinder petrol engine in her. I fitted the SABB last winter. She runs with less vibration at half throtle, so try to run her at that. Could I, and should I take out the rubber engine mounts, and bolt the engine directly to the frame, whould that help? |
