Bit of an orphan
Old Marine Engine » Unknown Engines - post here with photos » Bit of an orphan « Previous Next »
Stan Lyall
Username: stanute
Posted on Monday, August 07, 2006 - 05:02 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This is a single cylinder marine engine that was picked up in inland Australia being used as a stationary engine. So far, nobody can tell me much about it. Cast into the crankcase doors is the name "PLIX". The carby is an Australian made Alpha which appears to be a copy of a Schebler. I am assuming the carby is original.
Stan Lyall
Username: stanute
Posted on Monday, August 07, 2006 - 05:04 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Again
Stan Lyall
Username: stanute
Posted on Monday, August 07, 2006 - 05:06 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
More
Julian DuBois
Username: jules
Post Number: 33
Posted on Monday, August 07, 2006 - 10:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Sorry to disappoint but I believe the Plix engines rather than being marine were actually lighting plants hence the lightening bolt through the logo. There a couple of articles on Gas Engine Magazine, below is a link
http://www.gasenginemagazine.com/complete-archive/942/
Hope this helps, Jules
Stan Lyall
Username: stanute
Posted on Tuesday, August 08, 2006 - 09:28 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks for that Julian,, Not sure if the engine mentioned in that article is the same one,, however,, it is food for thought.
Daniel Dorece
Username: iron_wolf
Posted on Wednesday, August 09, 2006 - 01:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
These engines also went by the name Matthews. Definitely an engine from a gen set. It should have a plate with a set of points where the hole is.
Iron wolf
