1963 TROJAN SEABREEZE MOTOR
Old Marine Engine » Boats with Early Inboards » 1963 TROJAN SEABREEZE MOTOR « Previous Next »
1tm315
Username: 1tm315
Posted on Monday, August 14, 2006 - 06:04 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Can anyone tell me what kind of motor these boats have? The only marks that are readily seen are the words fireball and 188HP. I think it is either a GM or Gray marine motor but I am not sure. I want to buy a replacement crate motor but I need to know which motor will interchange and bolt up in all the right places. I am not a boat guy but I do know a little about engines and this one seems pretty standar, except for the flywheel being on the front??
I have attached a pic of the boat
Any help would be greatly appreciated!
Thanks,
Randy
larry_from_maryland
Username: larry_from_maryland
Post Number: 191
Posted on Monday, August 14, 2006 - 06:23 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
WE need a picture of the engine not the boat.
1tm315
Username: 1tm315
Posted on Tuesday, August 15, 2006 - 12:19 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Larry, thanks for responding. I am out of town this week and cannot take a picture of the engine. I had that picture on my phone from when I picked it up. I found a picture of the engine that closely resembles mine. It looks exactly like this one except the distributor and flywheel are on the front of the motor.
I will take a picture of the engine when I get home.
Thanks again for the help!
Post Number: 441
Posted on Tuesday, August 15, 2006 - 11:34 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The above pic is a Rambler 327. They made a real nice marine engine
1tm315
Username: 1tm315
Posted on Tuesday, August 15, 2006 - 03:05 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks! The picture above is not a picture of my engine though. It looks like the picture above only mine has the distributor and flywheel in the front. Do you know which motor I have?? And which motor will interchange with it?
Post Number: 442
Posted on Tuesday, August 15, 2006 - 03:32 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Compare the valve covers. They are the give away to the Rambler engine. If yours is a Rambler it won't interchange with anything else. (that I remember that is) Been many years since I worked on one.
