Perkins 4-108 Tappet Clearances
Old Marine Engine » Diesel Inboards » Perkins 4-108 Tappet Clearances « Previous Next »
amy_ann
Username: amy_ann
Post Number: 19
Posted on Saturday, June 24, 2006 - 10:23 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello All,
Not really a very old engine here(20yrs), but cannot get the valve clearances anywhere this evening in a bit of a fluster while trying to get back in the water before high tide this afternoon.
Can anybody help with this one ?
Regards - Pat.
larry_from_maryland
Username: larry_from_maryland
Post Number: 176
Posted on Saturday, June 24, 2006 - 06:31 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I can't find that engine in any of the truck or tractor service manuels i have.The majority of perkins engines have the valves set at 12 tho.both intake and ex.The next larger size above yours has the valves at 10tho.
amy_ann
Username: amy_ann
Post Number: 20
Posted on Sunday, June 25, 2006 - 08:16 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thanks Larry,
That's good enough for me at the moment. Can't go far wrong with either of these clearances. By the way it is a marine version i'm working on so that probably explains it not being listed in your manuals.
Regards - Pat.
Teddy
Posted on Wednesday, July 05, 2006 - 12:26 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi,
Is anybody can tell that what is advantages and disadvantages of 2 and 4 storke engine?
Knowledge of an angle. Claculation and movement of a given crank angle on the flywheel?
Thank you then!
Teddy
