Gray Marine 175 engines - parts avail...
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Gray Marine 175 engines - parts available? « Previous Next »
Jim Garver
Username: matthewsguy
Posted on Tuesday, July 18, 2006 - 11:21 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a 1947 Matthews boat with twin Gray Marine 175 engines, Continental 363cid six cylinder. So far I am unable to locate parts for these engines or the Paragon gearboxes. Lots of manuals on the internet, no parts. At a minimum, I need two head gaskets and an exhaust valve. I might be able to save these engines (they were under water), but with no parts I will have to remove them and install something else. Is this the same as the Continental M-363 tractor motor? Thanks for any help...
Jim Garver
Posted on Sunday, July 30, 2006 - 01:29 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Seeing no followups and having exhausted most avenues of info, I am considering selling or parting out these 363 Continental engines and possibly the Paragon reduction drives as well.
503-543-8664 if interested. Scappoose, Oregon
Andrew Menkart
Moderator
Username: andrew
Post Number: 691
Posted on Sunday, July 30, 2006 - 10:43 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Jim,
For parts you could try Dubie Marine in Tonawanda New York.
If you decide to sell them you could post them on our classifieds.
JOHN DEBATES
Posted on Monday, July 31, 2006 - 11:17 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
JIM
TRY WWW.GRAYMARINEPARTS.COM FOR PARTS AND INFO.
JOHN
