The Kick of The Pope's Mule
Old Marine Engine » Miscellaneous » The Kick of The Pope's Mule « Previous Next »
Post Number: 1160
Posted on Tuesday, June 20, 2006 - 02:20 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The Kick of The Pope's Mule -1916
KP
searcher
Username: searcher
Post Number: 117
Posted on Tuesday, June 20, 2006 - 04:57 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Richard,
I am sure glad you post this stuff. Otherwise, I would never have known that this one is a Joe's Gear, that it is an aftermarket device, and, that it is missing the leg extensions and the crankshaft sprocket. The upside is, now I won't feel guilty if I use the skiptooth chain and the small sprocket off it to restore the waterpump drive on an oddball engine I have.
foxman
Posted on Tuesday, June 20, 2006 - 07:24 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Nooooo don't do that I would be interested in this device as it would help a starting problem I have had with one of my large 2 cycle triples. Do you have a phone #?
searcher
Username: searcher
Post Number: 120
Posted on Sunday, June 25, 2006 - 09:33 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Sorry I have not responded sooner. If I eventually find a better solution for fixing the odd ball engine than robbing parts off this, I will contact you. It goes against the grain to rob parts but sometimes one has to decide what stays and what doesn't.
