MichaelRidout
| Posted on Tuesday, May 10, 2005 - 10:40 am: |
What is the normal rotation of a Gray 4 cylinder? CW or CCW? Is that viewed from the flywheel end? Does that mean a right or left hand prop? I have the right size and pitch prop, but it is LH. If right hand is normal, I don't suppose you can just run it with the tranny in reverse, can you? Mick Ridout [email protected] |
Doug Denton
| Posted on Friday, July 14, 2006 - 03:40 pm: |
I am new to your site, but full of hope! I have an old Chris Craft boat with a 4-cyl gas Gray Marine Four-85 engine, and it is giving me starting problems. Could anyone advise me where I could obtain the ignition specs as well as the timeing procedure and related specs for this engine?? A manual that would describe the coil, distributor, etc., would really make my problem a lot easier. An advice you have will be appreciated. Thanks Doug |
