Gray Marine V-8 Fireball
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Gray Marine V-8 Fireball « Previous Next »
Guy & Karen Vecchitto
Username: lucky13
Posted on Wednesday, January 11, 2006 - 07:54 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
We have a 1964 Tollycraft with twin V-8's. Are the parts for these hard to get? They are V8C-225's with about 1000 original hours on them. We would like to keep them rather than replace them. The boat is new to us.
Andrew Menkart
Moderator
Username: andrew
Post Number: 1329
Posted on Thursday, January 12, 2006 - 06:27 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The V8C-225 is the 327 cid engine, 225HP @ 4400 RMP.
Parts should be generally available for that engine, with the possible excemption of manifolds.
You can get manuals for it on the MarineEngine.com site.
For parts you could try Duby Marine in NY. 716-694-0922
Username: lucky13
Posted on Thursday, January 12, 2006 - 07:02 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thank you for the info. There has been much debate as to the manufacturer of these engines. So far it's been narrowed down to 2 possible companies, either GM or Rambler. Could you possible shed any light on this for us?
Andrew Menkart
Moderator
Username: andrew
Post Number: 1330
Posted on Thursday, January 12, 2006 - 08:15 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
AMC , same as the AMC Rambler (to the best of my knowledge).
Cal Martell
Username: seajay
Posted on Saturday, January 14, 2006 - 11:51 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I also have this engine in my '63 Century Sabre and am currently in the process of removing the engine from the boat for a rebuild. If you are interested in the linked discussion of the project here is a link. http://www.marineengine.com/discus/messages/12512/13970.shtml?1137118832
Both Andrew and "Fastjeff" have been extremely helpfull on this engine and if you are planning on doing the work yourself I would highly recommend the service manual that is available. If you would happen to have an extra pushrod laying around let me know.
Cal
