Auto-Lite distributor
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Auto-Lite distributor « Previous Next »
Paul Spratt
Username: pspratt
Posted on Monday, September 18, 2006 - 06:50 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have an auto-lite distributor on a Lugger Sea-Scout 91. I cannot make out all of the info, but I can read the numbers 116, auto-lite, and what looks like a g6. Anyone know where to look for replacements for this? While setting the gap, we noticed that the mount for the rotor wobbles a bit. I have to think that the wobble is bad for the gap setting and am thinking that I need to replace the whole thing. Any advice is appreciated.
JOHN DEBATES
Username: cam_gear
Posted on Tuesday, September 19, 2006 - 11:13 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
PAUL
YOU CAN TRY GRAY MARINE INC. AT 630-584-9141
JOHN
Lawrence T Wolfe
Username: larry_from_maryland
Post Number: 203
Posted on Tuesday, September 19, 2006 - 12:24 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Napa has them listed in the marine cataluge.
Douglas J. Beattie
Username: gannet
Post Number: 7
Posted on Wednesday, September 20, 2006 - 09:52 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Paul,
Van Ness Engineering in New Jersey sell a replacement electronic distributor. It's a bit pricey ,but you never have to replace the points or condensor. It is nearly impervious to moisture and the cap rotor and plug last a whole lot longer. I' ve had mine now for 5 yrs. and haven't done a thing to it. If she doesn,t want to start it's got to be the fuel system.
Doug
Paul Spratt
Username: pspratt
Posted on Sunday, October 08, 2006 - 12:17 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Thank you all for your help...I will be rebuilding portions of this old engine this winter...
Thanks again,
Paul
