starting an inboard out of the water
Old Marine Engine » Multi Cylinder Gas Inboards » starting an inboard out of the water « Previous Next »
richard kirsh
Posted on Thursday, July 31, 2003 - 09:04 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
i just bought a 1964 chris craft super sport with a 210hp chevy/chris craft engine. anyone know how to test run such an engine out of the water? there is a water pick up under the boat, but i dont know if there is any way to supply water artifically.
Eddie
Posted on Thursday, July 31, 2003 - 11:08 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Richard,
You should be able to get an adapter from a marine store to put on garden hose.
Eddie
richardkirsh
Posted on Friday, August 01, 2003 - 03:36 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
thanks eddie, i'll see if i can get one.
Richard Day
Posted on Saturday, August 02, 2003 - 07:53 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I would be careful to make sure the engine is running before applying water pressure to the cooling system otherwise you may force water into the cylinders through the exhaust system. Take it easy on how much water pressure you apply.
richard kirsh
Posted on Saturday, August 02, 2003 - 10:03 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
how long can you rin one of these engines before it starts overheating/ruining components?
Richard Day
Posted on Saturday, August 02, 2003 - 02:03 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Depends on wet or dry exhaust, rubber water pump impellers don't last if they are dry. I wouldn't run more than about 30 seconds as you don't know what is in the exhaust line that could be quickly damaged. For example rubber mufflers, steam hose connections. Personally I would arange to disconnect the water inlet from the through hull and connect it with a short length of hose into a dry wall bucket full of water. Run your garden hose into the bucket to make up water being pumped out by the engine. Fill the hose connected to the pump inlet with water so the pump picks up water quickly and gets lubricated quickly then shove the hose into the bucket making sure the pump continues to pick up water. Check water flow at exhaust to make sure all is working as it would if the boat was in the water.
Posted on Tuesday, August 12, 2003 - 02:44 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I did this trick on my Buchanan Midget a couple of years ago after the engine had been sitting for 3 years ( it took me that long to restore the hull). I fed the garden hose into the intake of the water pump - I simply undid the rubber hose to to the thru-hull fitting and connected the garden hose. I too was worried about water getting into the engine, but simply making sure the boat is level should make sure you've got enough slpoe to drain the water out to the exhaust.
I ran it this way for several hours and was able to warm up te oil and engine so that I could get ALL of it out of the engine - I let it drain for 2 days.
I was able to crudely control the temperature of the engine by controlling the flow of water. I found that the engine did not heat up too much because it was not loaded.
Miro
Ed
Posted on Friday, August 31, 2007 - 05:31 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I want to start my 3.0L Mercruiser I/O out of the water. I have a pair of 'mouse ears.' I was wondering the correct steps in testing the engine without burning it out of course.
Do I put the ears on, start the water running and try starting the engine?
Ed
Brian Hanson
Posted on Tuesday, July 14, 2009 - 05:16 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Ed, you are correct.
bluecometk
Username: bluecometk
Post Number: 9
Posted on Friday, July 17, 2009 - 09:56 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Gentleman be careful when starting inboards on land if the shaft is still connected you could ruin your cutlass bearing. Most older transmissions will creep in forward or reverse and the prop will spin and on a dry bearing it’s the kiss of death. You can stop the prop by blocking it against the strut or using line to tie it to the strut. The best thing is to disconnect the shaft.
These are just my opinions.
Bluecometk
russbucket
Username: russbucket
Posted on Wednesday, August 05, 2009 - 10:14 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I made an adaptor using a plunger an a hose fitting. I leaks enough so the water runs down the shaft into the bearing but be very careful as suggested. Also, the shaft seal also needs to stay wet.
custom_marine_engines
Username: custom_marine_engines
Posted on Monday, August 10, 2009 - 12:50 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
When running an inboard on land I second what most people have already stated; you should disconnect the propeller shaft, and run a hose to a bucket so that the engine sucks water not a hose forcing water in. Good luck with your Chris Craft!
aqualife
Username: aqualife
Posted on Monday, October 25, 2010 - 03:39 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I just picked up a 1970 Concord 30'. It has dual Chrysler motors that I've been told have been sitting for about a year, but are still in good condition. What should I do to prep the motors before trying to start them? Also, is the method of getting water to them the same as the chris craft or...?? (It's out of the water right now) please help. This is my first boat and I don't wanna ruin it.
Post Number: 509
Posted on Monday, October 25, 2010 - 11:10 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I think common sense will apply here.
1) disconnect the drive shaft - see comments above.
2) make sure you've got good oil in the crankcase.
3) pull the spark plugs and squirt one or two shots of motor oil into the cylinders
4) with he plugs still out, crank the engine until you see some oil pressure - should be 15 seconds or so - it always seems longer
5) put the plugs back in and asuming your fuel system is OK - see if it will fire - you can let is run for 5-10 seconds, then shut it off
6) make some arrangement to get water to the engine and turn on the water tap - you'll eventually ought to see water dribbling out of the exhaust - start the engine and you should now be OK to run for a while
Remember it is not loaded so it won't get hot very quickly
It usually helps to have really good batteries - you'll need 'em
