Winter project
Old Marine Engine » Buffalo Gasolene Engine Co. » Winter project « Previous Next »
Post Number: 256
Posted on Sunday, October 09, 2005 - 08:29 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I purchased this engine before the Mystic trip, Ernie picked it up and delivered it to the show. It's going to be a winter project, maybe several winters, ours aren't that long. The manifolds will have to be fabricated unless I find a parts engine. The internal parts look good, one half of the rod big end is missing. Two cylinders in great shape, the other two are stuck and have quite a bit of rust above the piston, may require a couple of sleeves. Several valves are stuck but that shouldn't be a problem. It's 10hp 4cyl, serial # is 807, should be an early motor. I'll see if the pictures will fit.
