boyd guard
| Posted on Tuesday, May 17, 2005 - 12:33 am: |
Have p5m, need a parts and o/haul manual. S/n of eng. is 67228. Can anyone help please. |
mike_sutcliffe
Member Username: mike_sutcliffe
Post Number: 7 Registered: 07-2004
| Posted on Tuesday, May 17, 2005 - 03:51 am: |
Hi boyd, I can help with photocopies the manual and other interesting information. Please email me with your postal address. Mike |
timmulvey
Post Number: 151 Registered: 05-2003
| Posted on Tuesday, May 17, 2005 - 07:31 am: |
Boyd - can you recheck the engine no. as it isn't covered by the ranges of engine nos. on my list. Also, I sent you a pic of a dipstick so you can fabricate youself. Email me if you want exact dimensions. |
chris_davies
New member Username: chris_davies
Post Number: 1 Registered: 07-2005
| Posted on Saturday, July 09, 2005 - 07:29 am: |
i have a p5m what is the correct spark plug gap as i renewed the plug and am getting a misfire which i did not have before and also what is correct ratio fuel mix and recommended 2 stroke oil |
mike_sutcliffe
Post Number: 11 Registered: 07-2004
| Posted on Saturday, July 09, 2005 - 07:21 pm: |
Chris, I use a Champion L86C which replaces the Champion L14 or UJ12Y as specified in the manual. Ask your local supplier what he has which is equivilent. A KLG F50 is OK as well. The Fuel mixture specified is 1 in 48 or 50. That is 100 ml of oil to 5 litres of petrol. I always use premium grade fuel as it lasts longer than ULP if not all used up. I have found that Outboard grade oil which is designed for water cooled engines works better than mower type two stroke oil in that there is very little oil residue in the exhaust. Do you have a P5 manual?? Mike |
mike_sutcliffe
Post Number: 12 Registered: 07-2004
| Posted on Saturday, July 09, 2005 - 07:24 pm: |
Chris, The correct spark plug gap is .025 inches or .60 mm for both magneto and coil ignition. Mike |
mike_sutcliffe
Post Number: 13 Registered: 07-2004
| Posted on Tuesday, July 12, 2005 - 12:05 am: |
Chris, I just checked my box of spark plugs and notice that the last plugs I purchased for the P5 are Champion D16. They seem to work very well and are quite cheap. Cheers, Mike |
chris davies
Member Username: chris_davies
Post Number: 4 Registered: 07-2005
| Posted on Monday, May 15, 2006 - 02:31 pm: |
can anyone advise approximately how many turns the brass air filter should be opened on a p5m as a guideline to starting as i have cleaned the main jet and unsure of the correct setting |
Peter Ogborne
Post Number: 133 Registered: 09-2002
| Posted on Monday, May 15, 2006 - 05:52 pm: |
Chris ....start at about 6mm [1/4 inch] and then decrease it until running is ok. Any more than 6mm and it will be too lean. |
