Id old engine-continental
Old Marine Engine » Unknown Engines - post here with photos » Id old engine-continental « Previous Next »
oakhillsmithy
Username: oakhillsmithy
Posted on Sunday, September 19, 2004 - 03:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
we found this engine in back of my dad's shop. id tag y400a530602r/tap cl in 12/ex 20/last #was on edge of tag 997755. since my dad at different times restored everything from vintage jaguars-tractors to boats we don't have a clue what this motor was for. it has power steering pump-torque converter and what looks like it might be a hydraulic pump on it. no idea whether it runs or not-any help would be appreciated-i really hate to scrap it if it's saleable. thanks
larry_from_maryland
Username: larry_from_maryland
Post Number: 171
Posted on Sunday, September 19, 2004 - 06:24 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
That is a y series engine that fits either a massy harris pony or pacer tractor.I don't have one,but the ponys don't have hydrolis usually.So it should be a 112ci engine for a pacer that has the hydrolics mounted to the engine.
oakhillsmithy
Posted on Tuesday, September 21, 2004 - 08:13 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
thanks for the info on the continental-we're pretty sure dad had a massy pony that didn't run and sold it just before he passed away-motor must have been for that thanks again
Dell Roberts
Posted on Wednesday, February 23, 2005 - 12:32 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The engine in question is a Y112 (112 cid) & a (Y Series Model) Continental. Designed ONLY to be used on a Clark Forklift (Front End Machining is special)
A.Ricketts
Posted on Tuesday, October 18, 2005 - 11:47 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Have picked up a grey marine 4 cyl. desial made by continental was new never run been stored at a local tech school say's it's a model HD277, what I wanted to know is what was this type engine used for and is it worth anything? Thanks
larry_from_maryland
Post Number: 273
Posted on Wednesday, October 19, 2005 - 12:38 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It was used in the massy harris 444 tractor.At 1500 rpm it was 49 hp.The industrial rateing at 2400 is 79hp.I am sure someone restoring a tractor would love to have it.Guys are always complaining about finding parts for thease old diesels.
mr marty
Posted on Friday, April 28, 2006 - 12:22 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
i have a problem , i have a clark forklift with a continental 6 cyl motor , last i used it it was running fine than lost power , come to find the distributor does not turn , any idea what could be the problem ,everything seems to look o k thanks for your time
Lawrence T Wolfe
Post Number: 154
Posted on Friday, April 28, 2006 - 11:47 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Something broke.It conld be the distributor shaft or the cross pin that holds the gear on or it could be a broken cam shaft.Normally the timeing gears don't break.You will just have to investigate untill you find the problem.If the distributor doesn't turn you likely don't have oil flowing either.
