Fuel supply
Old Marine Engine » Palmer Engine Co » Fuel supply « Previous Next »
Ben Sidaway
Username: ben
Post Number: 13
Posted on Wednesday, April 19, 2006 - 02:54 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I’m having trouble with my fuel supply to my M-60. Last season my fuel filter would collect all sorts of sludge from the tank. It would overwhelm the filter and end up clogging the carb. No problems once I cleaned the carb though. I added a disposable inline paper fuel filter downstream of the primary filter that has helped but I’d like to clean the sludge out of my tank. It is an aluminium 20-gallon tank with a filler pipe from the cockpit sole. I should have pulled the tank out when I had the engine out for a rebuild last year but I can’t do it now. Any suggestions apart from the obvious dumping carb cleaner etc into the tank?
Eddie Ross
Username: eddie
Post Number: 118
Posted on Thursday, April 20, 2006 - 11:36 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Being that this is a gereral marine problem, you might also start a thread on Marine engine discussion board. There are services at harbors that steilize diesel fuel tanks on your boat. You might want to find one of these outfits and see if there is a similiar service for gasoline tanks.
Ben Sidaway
Username: ben
Post Number: 14
Posted on Thursday, April 20, 2006 - 04:00 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Eddie,
Any discussion board you recommend?
Thanks.
Eddie Ross
Username: eddie
Post Number: 119
Posted on Thursday, April 20, 2006 - 11:13 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
www.marineengine.com Discussion board, Topic: Miscellanious marine engine related topics. Might even start a thread under Mercruiser. I know it has little to do with Mercruiser but that is an active part of the board and a gas tank is a gas tank regardless of engine.
