FUEL IN OIL ON A 318 CHRYSTLER MARINE...
Old Marine Engine » Multi Cylinder Gas Inboards » FUEL IN OIL ON A 318 CHRYSTLER MARINE ENGINE « Previous Next »
STEVEN LEACH
Posted on Wednesday, May 05, 2004 - 08:49 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I HAVE A 318 CHRYSTLER AND I STARTED IT UP FOR THE FIRST TIME IN 2 YEARS THE LIFTERS WERE MAKING SOME NOISE SO I TOOK THE VALVE COVERS OFF AND NOTICED THE OIL TO BE THIN AND IT SMELLED LIKE GAS SO I CHANGED THE OIL AND IT HAPPENED AGAIN.
Bruce
Posted on Wednesday, May 05, 2004 - 10:06 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Check your mechanical fuel pump diaphram-bet its cracked and leaking gas into the base. happened to me on my 6cyl Graymarine.
Dick Gibbens
Posted on Wednesday, May 05, 2004 - 10:36 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Does it have an engine mounted fuel pump? It might be that the diaphram is leaking into the base.
shawnstam
Username: shawnstam
Post Number: 10
Posted on Sunday, April 16, 2006 - 08:51 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
are the gas tanks above the engine.
