More Mystic 2004 pictures
Old Marine Engine » Shows - Engines Shows, Boat Shows, and Auction Info » More Mystic 2004 pictures « Previous Next »
rbprice
Username: rbprice
Post Number: 171
Posted on Saturday, September 04, 2004 - 08:26 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Here are a few more pictures from Mystic 2004
The gear box is a Carlyle-Johnson
The second engine is a Wilpen - new to me
Evinrude with Carlyle & Johnson gear box
Evinrude #1
rbprice
Username: rbprice
Post Number: 172
Posted on Saturday, September 04, 2004 - 08:28 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Andrew - when I pre-viewed these pictures they were stacked one above the other but when I posted them they were strung out to the right. How do I avoid that.
Bob
Moderator
Username: andrew
Post Number: 880
Posted on Sunday, September 05, 2004 - 10:11 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Bob,
You should put each "image tag or code" on a new line, use the "enter" key to put it on a new line. If you to that they should each start on a new line.
I will see if I can edit your message now to make them line up vertically.
Yes, I was able to edit it...
