dick
Member Username: dick
Post Number: 14 Registered: 07-2004
| Posted on Wednesday, January 02, 2013 - 11:39 am: |
Often when I am attaching pipe-threaded fittings (90 degree primers, elbows, carburetors, etc.) the alignment doesn�t end up at quite the right angle. I either have to leave them a little too lose or over-tighten them a bit more than comfrotable to end up with the proper orientation. Is there some proper way to handle this situation? Is there some sort of pipe dope that is gasoline or heat resistant that would work, but not without making removal impossible? Many thanks in advance. Dick |
Senior Member Username: miro
Post Number: 647 Registered: 11-2001
| Posted on Wednesday, January 02, 2013 - 05:01 pm: |
That's not an unusual dilemma. I have found that over-tightening by about 1/4 turn is OK but not much beyond that. If I cannot get them to fit, I'll usually run the offending male thread into a die to get a bit more thread cut on the fitting. I find it takes 2 or 3 tries to get it right. I use regular anti-seize compound to make sure I can release them in future. You really shouldn't depend on some "goop" to make the seal - the pipe threads are designed to seal metal to metal. miro |
gregoryan
Senior Member Username: gregoryan
Post Number: 104 Registered: 09-2004
| Posted on Thursday, January 03, 2013 - 04:19 pm: |
Filing the end of the pipe alters the thread start point, in the elect trade we had to do this when using metal conduit so boxes and fittings were in line. ...for example 8 threads per inch = 1/8� per turn so to alter start point 1 degree would require filing 1/8� divided x 360 degrees, a couple of swipes of the file. metric could be different and may be a file would not cut the mustard. |
dick
Post Number: 15 Registered: 07-2004
| Posted on Monday, January 07, 2013 - 08:21 am: |
Miro and Gregoryan, Thank you both for the tips; I'll give them a try. Dick |
bruce
Senior Member Username: bruce
Post Number: 351 Registered: 07-2002
| Posted on Monday, January 07, 2013 - 12:33 pm: |
Two words.. Teflon Tape |
