4 cyl 230 cu in motor info
Old Marine Engine » Multi Cylinder Gas Inboards » 4 cyl 230 cu in motor info « Previous Next »
Jim Burke
Posted on Friday, July 02, 2004 - 11:56 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am just starting to round up information about a 4 cyl motor I saw that was used as a marine engine. The facts as I know them are:
1. 4 cyl
2. Based on half of a 460 Ford motor
3. The cyl head and internal parts from the 460 would bolt on or in.
What I don't know is:
1. Under what name is it manufactured?
2. Is it still made?
3. If it is still made who sells them?
Thanks for any help, I appreciate it.
Rich Balza
Posted on Friday, July 09, 2004 - 10:34 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Jim , the MERCRUISER 224cid used a sleeved aluminum block with a 460 head and delco ign.Bore 4.36 (same) but stroke 3.75 instead of 3.85 in the 460. The head is the same and they were popular on high end boats in the 80's .I run one in my Formula a H.O."488" 470's 485's and 170mr&190mr are the mercruiser designations .Rich
Jim Burke
Posted on Monday, July 12, 2004 - 02:20 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Rich,
Thanks for the info, I appreciate it.
jim
Jim Burke
Posted on Tuesday, July 13, 2004 - 02:19 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Rich,
I was so happy to get a response that I forgot to ask if you would share some information about your motor. I was wondering about what type of crankshaft it has and what kind of durability do you get from the engine. You can answer here or if you prefer please e-mail me at [email protected].
thanks
jim
mart
Posted on Sunday, August 08, 2004 - 03:31 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The 3.75 inch stroke is the same as the 429 Ford V8 which was the predecessor of the 460. 429's used the same bore and rod length as the 460 with the difference in stroke accounted for by a different (lower) pin height in the piston, so I believe 429 pistons would also work in this block.
poker casino346
Posted on Monday, March 06, 2006 - 01:28 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
poker casino poker 13
