| Posted on Monday, November 04, 2002 - 11:05 am: |
Luke Tonneberger from Rockford, MI, USA provided the following links of old pictures of an single cylinder marine engine. http://image.slnsw.gov.au/homeaway/13/d6_13376.jpg http://image.slnsw.gov.au/homeaway/13/d6_13378.jpg http://image.slnsw.gov.au/homeaway/13/d6_13380.jpg They seem to be posted on an Australian government site. Regards, Andrew |
marks
| Posted on Monday, November 04, 2002 - 10:54 pm: |
These are from the State Library of New Soth Wales on line collection. Unfortunately they are only described as "Engine" from 1936. The first one looks a bit Chapman'ish(I'll check the brochures tonight) but the other pictures of the same engine? I have never seen a transmission the same as that but it does bear a resemblence to the later Blaxland units with the separate transmission and mounting bracket. Mark S. |
| Posted on Monday, November 04, 2002 - 10:59 pm: |
Mark, Thanks.... is there an index page or search feature for that online collection? Do you know the URL? Regards, Andrew |
marks
| Posted on Monday, November 04, 2002 - 11:14 pm: |
Hi Andrew, Yes there is: http://www.slnsw.gov.au/picman/comb.cfm This is the advanced search. Select the frame no from the drop down box and key in either 13376 or 13378 or 13340. There are some great pictures on this site of marine history related things. However the collection is very large, i think maybe 20,000 items Regards Mark S. |
Devon Amber
| Posted on Tuesday, January 21, 2003 - 07:39 am: |
Hi I have one of these engines exactly the same it is a Simplex Mine has Simplex cast into each side of the cylider water jacket I have that away at the moment being welded as it had blown out with corosion damage Regards Devon Amber South Australia |
Steve OBrien
| Posted on Wednesday, January 29, 2003 - 08:10 pm: |
Hi Devon What kind of simplex do you have? The 3hp is apparently quite rare. Check out Kevin Hickey's (Hobart) elsewhere on this discussion board. See also other's advice (including Peter Ogborne (WA)) that welding should be avoided if possible. EPIGEN epoxy apparently works fine for repair of even huge holes in the cooling jacket. Steve O'Brien Brisbane |
Peter Ogborne
| Posted on Thursday, January 30, 2003 - 07:25 am: |
Just to reinforce my my use of epigen to repair big cutouts on water jacket walls. What i have used to build up the patch is a piece of "Termimesh '' .Again stuff the inside of the hole with Styrofoam as a ''backing '' for the Epigen . |
