John M
New member Username: jhkm12345
Post Number: 1 Registered: 05-2016
| Posted on Friday, May 13, 2016 - 01:14 pm: |
ID Tag says model #122 RD or PD, cannot tell which. 6 cylinder flat head twin updraft zenith carbs f6-208 is cast into the intake balance pipe between the carbs. https://goo.gl/photos/Hid5YhGHGGQuMkKLA https://goo.gl/photos/vbPQ3KBawasUxnZx8 https://goo.gl/photos/4QYhUrEEHgZCiMuCA https://goo.gl/photos/jGZ3iEcsHYLWrqwm6 |
Jim Staib
Senior Member Username: drrot
Post Number: 200 Registered: 09-2008
| Posted on Sunday, May 15, 2016 - 11:11 am: |
date on manifold looks like 11-23-59. Post the numbers on the small round disc on carburetors. |
John M
Post Number: 2 Registered: 05-2016
| Posted on Monday, May 16, 2016 - 06:51 pm: |
the numbers on the carbs is 96850 OR 9685C https://goo.gl/photos/5fUCNEP93f7id2Aa6 |
Jim Staib
Post Number: 201 Registered: 09-2008
| Posted on Tuesday, May 17, 2016 - 10:28 am: |
Phantom 6-103HP
John M
Post Number: 3 Registered: 05-2016
| Posted on Tuesday, May 17, 2016 - 02:07 pm: |
But what you're listing there shows 1940-52 which is too early for this motor (based on the 1959 casting date you pointed out) also it lists the carb stamp as a 'c' which is not listed here. I'm not trying to be obstinate, but this still doesn't seem right. That's an awfully early motor for a fiberglass boat from 1963. Also, it looks like a 103 would have the tach cable drive out of the center of the cylinder head, which mine does not. |
Jim Staib
Post Number: 202 Registered: 09-2008
| Posted on Wednesday, May 18, 2016 - 10:18 am: |
The book is from 1952
tedjohnson
| Posted on Monday, September 19, 2016 - 03:24 pm: |
all: I have a lugger six-330 engine(Grey Marine) and need to know where the spark plugs are oriented on the head, ike 1 to 6 locations and reelevent to what?(flywheel, distributor, etc. Ted at [email protected] |
Ned Lloyd
Senior Member Username: ned_l
Post Number: 64 Registered: 08-2012
| Posted on Thursday, October 20, 2016 - 10:40 pm: |
Do you mean "what is the firing order?" Six cylinder engines are about the only engines with a universally consistent firing order. 1-5-3-6-2-4. #1 cylinder is forward over the flywheel. |
