Cylinder head temp thermistor Gray ma...
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Cylinder head temp thermistor Gray marine 100- need one « Previous Next »
gulper
Username: gulper
Posted on Thursday, August 04, 2005 - 07:52 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Do you know where I can get a Cylinder head temp sender for a gray marine 100 engine.
frankco
Username: frankco
Post Number: 10
Posted on Tuesday, October 18, 2005 - 12:51 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I bought a standard temperature sender then bought a brass adapter from Lowes or www.antiqueboat.com/index2.asp.com. where it is $15.99. This is for a 12 volt conversion. I bought the sending unit on ebay.
