Chrysler 318 low compression
Old Marine Engine » Multi Cylinder Gas Inboards » Chrysler 318 low compression « Previous Next »
pluckiebaum1
Username: pluckiebaum1
Posted on Monday, August 29, 2005 - 01:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
ok need a little help here I have a 1963 chrysler 318 that I just had the top end redone on ( new heads intake ect) but now it has low compresion and it acts like the rings are shot is there a way WITH OUT taking the motor out of the boat to try and get the copression back up and the rings working again. here is what i got #1 95psi #2 60psi #3 85psi #4 65psi #5 70psi #6 80psi #7 60psi #8 60psi any help here would be great the motor did sit for about a year with the heads off
but was under cover and still turns over realy well .....Justin
solarrog
Username: solarrog
Post Number: 168
Posted on Monday, August 29, 2005 - 01:32 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Sounds like you picked up some rust in the valve area, The best way is to pull the heads.
The lazy way is to run is and see if it improves
generally it will (some) but it will never be right till you serves the heads
pluckiebaum1
Posted on Monday, August 29, 2005 - 01:46 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
thats the problem i cant get it to start at all i have spent the last 3 days playing with it trying to get it to start and it won't there should be no rust in the motor at all New heads ? will the motor or should the motor run with that low of compression ?
pluckiebaum1
Posted on Monday, August 29, 2005 - 01:47 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
i should have said that first sorry about that
solarrog
Username: solarrog
Post Number: 169
Posted on Monday, August 29, 2005 - 02:25 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
The oil pressure may need to fill the lifters before your compression reachs normal
and yes it should start with compression in that range
pluckiebaum1
Posted on Monday, August 29, 2005 - 04:32 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
lifters are full but still nothing im at a loss thanks for all your help but it looks like i may need a new motor have you ever heard of putting reslon down the cyld and letting it sit for a few days someone said that might work to free up the rings ?
solarrog
Username: solarrog
Post Number: 170
Posted on Monday, August 29, 2005 - 05:30 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
If the engine has been rebuilt and no water has entered the engine, The rings do not need freeing up. The most likely area is the valves. If they have any adjustments, back them off, If they are without adjustment, it is my opinion that the heads need to come off. Double you money back warranty. Guess there isnt anything else I can do to help.
pluckiebaum1
Posted on Tuesday, August 30, 2005 - 08:52 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
UPDATE : it runs thanks for all the help i needed to back the valves off a little but after that boom she came back to life thanks for all your help
solarrog
Username: solarrog
Post Number: 171
Posted on Tuesday, August 30, 2005 - 11:44 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Great glad to here it
Roger
Pete Hartman
Posted on Monday, November 14, 2005 - 09:37 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a Chrysler LM318 with a closed cooling system of unknown manufacture. Has a cast expansion tank front top center of engine that appears to double as thermostat housing. There is no thjermostat, and I am told that this type of cooling system does not work well without a thermostat, but I can't identify the thermostat I need. Any ideas??
