Spark Jumping at coil
Old Marine Engine » Timers, Magnetos, Ignition » Spark Jumping at coil « Previous Next »
jamesosler
Posted on Wednesday, September 21, 2005 - 02:24 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a Scripps 4 clyinder and the points and coil and condenser and in great shape. but know the spark seems to jump from the - side to the terminal of the coil and the the spark jumps from the + side to the terminal of the coil. Any help would be great thanks
James
Post Number: 251
Posted on Wednesday, September 21, 2005 - 06:52 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Sounds like you have a bad plug wire, if you have high resistance the spark will find another way out. If it's been doing this for a while it may have carbon tracked the coil, it will need to be replaced along with the boot.
