Seascout Propeller
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Seascout Propeller « Previous Next »
ejgaudet
Username: ejgaudet
Posted on Wednesday, July 06, 2005 - 10:36 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
What size propeller is needed for a Seascout 91? Do you know of any sources for such props?
frankco
Username: frankco
Post Number: 11
Posted on Tuesday, October 18, 2005 - 01:01 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Does the graymarine 100 engine with a capitol 1E transmission use a left or right hand prop? I have the prop from the chris craft k model engine; will this prop work the boat is a 1941 barrelback. large pitch but only 9" prop left hand drive.The manual calls for a 13 x13 prop but does not indicate rt. or left.
