williamjchampion
| Posted on Tuesday, August 23, 2005 - 10:22 am: |
My P-60 has recently picked up the annoying habit of fouling the #1 and #3 plugs almost immediately. #2 and #4 are not doing this. Any thoughts? Timing problem? |
eddie
Senior Member Username: eddie
Post Number: 69 Registered: 04-2003
| Posted on Tuesday, August 23, 2005 - 01:43 pm: |
How often do you change distributor cap and rotor? What ptug are you running? What gap? What is the inside color of the plug ash on the used/fouled plugs? How old are your plug wires? |
williamjchampion Visitor
| Posted on Sunday, August 28, 2005 - 08:34 am: |
Eddie, the plugs are D-16s gapped to .028. The cap, rotor and wires were new last year, and probably have less than 10 hours on them. The plugs that are fouling are black and a bit oily. The other plugs have a tannish color to them. |
eddie
Post Number: 70 Registered: 04-2003
| Posted on Sunday, August 28, 2005 - 05:39 pm: |
Did you use a spark plug socket, with rubber insert, to install the spark plugs? Where did you get the spark plug wires? Good work on the cap and rotor. With a point system it is good to change the cap and rotor every year. Observe the porcelien insulation on the fouled plugs carefully for hair line cracks. |
