Carter bb-1
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Carter bb-1 « Previous Next »
Dan m
Posted on Friday, November 11, 2011 - 06:35 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Does anyone know about the adjustment on the carter carburetor. when running I seem to have to play with the choke alot to keep it running. Is the choke set at a certain point? Or should it be open all the time when running.any advice can be helpful.thanks
Jim Staib
Username: drrot
Post Number: 107
Posted on Saturday, November 12, 2011 - 07:42 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It should be full open once the engine is warmed up.
Dan m
Posted on Sunday, November 13, 2011 - 03:10 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Maybe a jet problem?
