1939 gray 6-125 running too rich
Old Marine Engine » Boats with Early Inboards » 1939 gray 6-125 running too rich « Previous Next »
ekvisto
Username: ekvisto
Posted on Thursday, June 16, 2005 - 10:55 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
i have a 42 utility with a 1939 gray marine 6-125 engine. i am trying to get it ready for the summer but after getting it running one time i pulled the plugs and they were very black and carboned up. also while it was running the engine was blowing some black smoke out the tail pipe. i think that it is running too rich but i am not sure how/where to adjust the mixture to be more lean. any ideas would really help.
thanks,
eric
Post Number: 181
Posted on Friday, June 17, 2005 - 04:48 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Depends on the carburetor. You should see a small adjustable needle valve on the side or the bottom of the float bowl.It usually has a small cross bar on it.
It should be set you about 1 1/2 turns out from the fully closed setting.
Or you might try getting the enfine warm - black smoke and all - and then closing ( screwing IN ) the needle vavle until the engine begins running better - you'll be able to hear the change in the enggine sound.
Right now I'll bet it sort burps - whaeras when set right it should just tick over .
