HELP ! - Gearbox to propshaft connec...
Old Marine Engine » Stuart Turner » HELP ! - Gearbox to propshaft connector - P5 Marine « Previous Next »
philip hadfield
Username: major_taddy
Posted on Saturday, July 21, 2012 - 08:38 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I am giving my P5 a top end rebuild and see if I can get it going , last owner blew the head gasket, if I am succesfull I will be fitting it into my boat.
I also have a set of ST sternegear, with a 1/2" shaft, this has a "scoop" about an inch from the end, and also a groove for a woodruff key
The circular fitting on the gearbox output shaft has 3 holes in it.
Is there a specific part that will connect the end of the prop to the end of the gearbox ?
does anyone on the forum have one available ?
or do I need to get a flexible coupling made up.
steven john page
Username: fairbanks
Post Number: 97
Posted on Saturday, July 21, 2012 - 04:14 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Phil, you need a three bolt flange , one of which i have spare, how ever it does have the remains of an old bronze shaft still in situe, its yours if you are still interested. regards steve
philip hadfield
Posted on Sunday, July 22, 2012 - 08:25 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Steve,
Great news, many thanks, that would be very helpful, do you have a contact tele number I can ring you on please. you can send details to : [email protected].
