Palmer P 392 IH fuel pump rebuild?
Old Marine Engine » Palmer Engine Co » Palmer P 392 IH fuel pump rebuild? « Previous Next »
Scott Downey
Posted on Sunday, May 23, 2004 - 06:17 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have replaced the original fueel pump because the diaphram leaked. This pump is bolted together so I suppose a new diaphram would fix it.
Where can you get a diaphram rebuild kit?
Also this pump has the inner diaphram on top of the other sealing gas from entering the crankcase, however, there is only a weep hole on top to let you know the diaphram failed, no tube to run to the carb as current CG regs specify.
Kevin Decker
Posted on Friday, June 11, 2004 - 10:16 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hi Scott,
Try http://www.marineexhaustmanifolds.com. Here's the contact info:
821 Waterway Place
Longwood, Fl 32750
1-800-262-2929 or fax 407-323-8926
Jack Chamberlain is the proprieter. He had parts for an obsolete Sherwood water pump I have on my Palmer P-60, so he might be able to help you.
Good luck!
poker casino282
Posted on Monday, March 06, 2006 - 06:18 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
poker casino poker 39
