Dean Paul
| Posted on Saturday, April 16, 2005 - 01:32 am: |
I have a Palmer P60 in a 1973 Islander 30 MKII. While the engine has run fine for over 30 years I would like to add a tachometer as I am changing over to a Flexofold folding propeller. Any ideas how to do this? |
lonny Visitor
| Posted on Saturday, April 16, 2005 - 08:46 am: |
Moyer Marine has a 4000 rpm tach that is easy to wire and works great. I also added the heat exchanger they offer. I moved to Fl. and didn't like the idea of running salt water through the engine. |
Karl Burton
| Posted on Thursday, April 21, 2005 - 05:49 pm: |
Because I knew a friend who worked for Stewart-Warner, I got a mechanical tach - there's a port for a mechanical tach on the back of the "accessory drive" thing. If I recall correctly, you need to specify that it's for a gas engine, where it's driven at 1/2 crank speed, rather than a diesel. |
Mark Livingston
| Posted on Monday, May 09, 2005 - 01:46 pm: |
I have a mechanical tach, and need a cable. Where do I get one? The manufacturer is Hudson, apparently. |
Post Number: 239 Registered: 07-2002
| Posted on Tuesday, May 10, 2005 - 07:18 am: |
Truck repair shops keep kits to make tach and speedo cables, everything is cut to length and crimped together. They may be able to help. |
Karl Burton
| Posted on Wednesday, May 18, 2005 - 07:31 pm: |
Try a place that outfits/creates/repairs taxicabs. That's where I got the cable for my mechanical tach. I think I found them by looking under "speedometer repair" in the yellow pages. They're all involved in speedometer and cable and instrument stuff because of having to install taximeters and calibrate odometers - though perhaps nowadays it's all electronic. |
