Update head gasket
Old Marine Engine » Palmer Engine Co » Update head gasket « Previous Next »
robert_ray
Username: robert_ray
Posted on Tuesday, May 17, 2005 - 09:18 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
got the head off and the gasket is copper/sandwich type, came off easily. it's obvious where it failed, two cylinders had water in them. the cooling water channels are fairly clean, my question is should I replace the head bolts and what do I flush the cylinders out with to remove moisture?
Thanks, Robert Ray
