Gray marine 4 - is there a replacement?
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Gray marine 4 - is there a replacement? « Previous Next »
ericb
Username: ericb
Posted on Saturday, September 25, 2004 - 10:06 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a friend who has a Gray 4 Lugar (sp?) in a Kettenberg 38. The engine needs a rebuild but he can't afford the $7K they want. Is there a substitute 4 cyl car motor one can use as a replacement? This probably sounds like heresy to some but it is the only way he will be able to afford getting it going, unless you know of an engine rebuild in So.Cal. for a lot less. Thanks
chuck harder
Posted on Sunday, May 08, 2005 - 10:24 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
i have a 4-85 with gear box runs
poker casino853
Posted on Monday, March 06, 2006 - 01:48 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
poker casino poker 976
