135 Graymarine engine 4 sale |
Dale Spencer
| Posted on Monday, May 16, 2005 - 02:05 pm: |
I have a complete motor w/trans and drive line . Pulled running . One carb was damaged loading it up . Please call me 715-662-2140 if interested . |
Moderator Username: andrew
Post Number: 1148 Registered: 11-2001
| Posted on Monday, May 16, 2005 - 05:46 pm: |
Dale, You should post that on our classifieds. |
Jack Gifford
New member Username: ny_giff
Post Number: 1 Registered: 11-2007
| Posted on Saturday, November 10, 2007 - 12:57 pm: |
I recently purchased a 1948 Century from which the original engine was removed and replaced with a Gray Marine 6 cyl with single carb. There was little information supplied with the boat and no markings on the engine except for the plate on the transmission that reads "6-244 Express" Would appreciate info on horsepower, etc. |
Ken Bleier
New member Username: kjmb1
Post Number: 1 Registered: 12-2007
| Posted on Saturday, December 08, 2007 - 05:51 pm: |
I have a Graymarine V8c-178B. It was last used in salt water, but I am rebuilding it and will only use it in fresh. My problem is, both cylinder heads and both exhaust manifolds are corroded through. I have not had much luck locating these parts. Someone said AMC engine parts will fit, how will I know what part numbers? Thanks, ken |
