M-60 water pump oil leak
Old Marine Engine » Palmer Engine Co » M-60 water pump oil leak « Previous Next »
ben
Username: ben
Posted on Thursday, May 19, 2005 - 12:06 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
After running my M-60 I notice oil leaking out of the seal around where the water pump drive shaft comes out from the engine. I took this apart and found a thick rubber washer that looked OK but I suppose it must be worn. Am I correct in my thinking here? If so where can I get a new seal?
