Paragon transmission issue
Old Marine Engine » Boats with Early Inboards » Paragon transmission issue « Previous Next »
busboy
Username: busboy
Posted on Sunday, November 04, 2018 - 07:32 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
is there any "special" tricks to know when removing paragon transmission fro gray 620
ned_l
Username: ned_l
Post Number: 182
Posted on Wednesday, November 14, 2018 - 12:40 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
It should be straight forward. Drain the whole engine crank case, remove all the flange bolts between the reverse gear and the rear bell housing, pull the reverse gear 'aft' off the stub shaft.
Never did it on a 620, a Gray 109 a couple of times though.
