jerry shenk Visitor
| Posted on Friday, March 18, 2005 - 10:34 pm: |
I have a palmer NL-1. What is the lever for that slides the camshaft front to bach for? Do you move lever while engine is running? Also it has a large roller bearing for a thrust bearing. Is this original? thanks in advance jerry |
richardday
Post Number: 375 Registered: 11-2003
| Posted on Saturday, March 19, 2005 - 03:56 pm: |
Push back to start and as soon as the engine is running pull forward. It is a compression release and must be in the forward position when running or you will ruin the small lobe on the exhaust cam that give about 1/4 compression to start. The engine runs counter clockwise facing the flywheel. The thrust bearing should be a radial style not roller. If it is a radial stlye but has rollers then that would be suitable for the prop shaft thrust bearing. Do you have a serial number for the engine?? |
jerry shenk Visitor
| Posted on Monday, March 21, 2005 - 09:19 pm: |
Thank you for answering my question.All my engine has is Palmer bros, cos cob ct type 4 by 4, no tag. Would it be stamped anywhere else? I am glad you told me it runs counterclockwise,as I couldnt find any time marks so I timed it off tdc to run clockwise.Also must sleeve cylinder as compression is low . thanks jerry |
