Where should I look?
Old Marine Engine » Diesel Inboards » Where should I look? « Previous Next »
David Reid
Posted on Thursday, July 31, 2003 - 01:47 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
My wife and Iive aboard an old power boat. She was built in Victoria in 1934. She currently has a Perkins 6-354 that, while a good engine is too much for her. I have no plans to repower her soon, but am curious as to what a good choice would be. I would like something in the 50 to 75 hp range and would love it if it were old and appropriate for the vessel, assuming that it ran well and gave good service. I would love to find something and rebuild it so I could learn as much as possible about it. Suggestions? Thanx in advance.
Bert Bergen
Posted on Saturday, October 15, 2005 - 10:01 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have purchased a used Perkins 6 cylinder turbo and was informed the engine was 185 hp. How would I do a search using the serial number on the engine to determine the year built and the accurate model number and confirm the hp rating. Serial Number is TE8861U566763F. Any help would be greatly appreciated.
larry_from_maryland
Username: larry_from_maryland
Post Number: 270
Posted on Sunday, October 16, 2005 - 05:12 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have seen a table serial number listing for that engine ,but can't seem to find it again.
larry_from_maryland
Post Number: 271
Posted on Sunday, October 16, 2005 - 07:41 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Well i found some info.It was made in 1978 and probably in the usa,not england.Continous hp would be 125 to 135.Maximum hp would be in the 150 to 170 range.This is for engines running in the 2200 to 2400 rpm range.the numbers could go up if running faster.If a serial number looks like his the last letter denotes the year,B is 75,Cis 76,d-77,f-78.
poker casino200
Posted on Monday, March 06, 2006 - 02:19 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
poker casino poker 959
