gray marine model 70 flathead 4 |
jeff c
| Posted on Tuesday, November 13, 2001 - 03:35 pm: |
I am trying to wire this engine. On the starter there seems to be a connection for a larger wire directly on the casing. there is also a sileniod bolted to the starter with two smaller connections and what looks like a reset button. On top of the engine is the voltage reg. with amp, flow (which are hooked up) and batt. (which is open) The engine is 12 volt. Any ideas??? |
olarry
| Posted on Wednesday, November 14, 2001 - 07:23 pm: |
It sounds like you have a BENDIX starting system.They where used on ford cars,trucks,Massy harris tractors and many others in the 30's and forties.Your reset button is really a button to engage the selonid.The 2 small posts are connected(one on each side) to a push button,to engage the selonid.You should have one large post on the starter connect it to a big post on the selonid.The other big post goes to the battery.The regulator should have 3 posts ARM should go to the A or ARM post on the generator.Another post should be FIELD connect to F or FLD post on generator.The last is BAT connect to a good source going to the battery. |
warren a bain
| Posted on Tuesday, August 13, 2002 - 03:24 pm: |
I am looking for a chrysler coron M-47-S engine I need a block it is a 265 cu in. 135 h/p. My phone is (909) 7648247 this is my cell. I go by bud |
| Posted on Tuesday, August 13, 2002 - 03:54 pm: |
Bud, You can post a free "wanted ad" in our classifieds section. Regards, Andrew |
poker casino59 Visitor
| Posted on Monday, March 06, 2006 - 04:15 pm: |
poker casino poker 782 |
