cosmic_girl
New member Username: cosmic_girl
Post Number: 3 Registered: 07-2005
| Posted on Monday, July 25, 2005 - 11:02 am: |
does any one have drawings/plans of the ST gearbox. reverse gear works a bit but forward gear doesn't I have been told that prop shaft should move in and out when gears change.Any help or information would be greatly appreciated. Kate. |
peterogborne
Post Number: 261 Registered: 09-2002
| Posted on Thursday, July 28, 2005 - 07:25 am: |
Kate .........check the hex socket screw on the top of the gear box . Loosen the hex socket and then turn the brass nut . Set it so that pressure forward and astern is the same ...then lock the hex screw. If you can not move the shaft then get a piece of wood and a hammer and give the shaft flange a good belt. |
cosmic_girl
Member Username: cosmic_girl
Post Number: 4 Registered: 07-2005
| Posted on Monday, August 01, 2005 - 11:55 am: |
on top of the gearbox there is a hex screw(20mm) which seems to be an air vent. Inside i can see a spring on one side, however access is very limited. I'm afraid I have the wrong screw.The prop shaft is still not moving,after a medium strength whack.Again, it is difficult to get to.Should it really be moving in and out? How much? |
peterogborne
Post Number: 262 Registered: 09-2002
| Posted on Monday, August 01, 2005 - 09:31 pm: |
I will send some explanatory pics |
cosmic_girl
Post Number: 5 Registered: 07-2005
| Posted on Tuesday, August 02, 2005 - 02:21 pm: |
I live in hope...Thank you very much. |
poker casino877 Visitor
| Posted on Monday, March 06, 2006 - 01:43 pm: |
poker casino poker 901 |
