Need help with slipping clutch
Old Marine Engine » Gray Marine Gas Engines - 4, 6, and 8 cylinder » Need help with slipping clutch « Previous Next »
curbsidegold
Username: curbsidegold
Posted on Sunday, November 21, 2004 - 10:58 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have a mid 60's Graymarine 4-75. It has a capital gear clutch that slips in forward gear...the lever fails to 'snap' into place. I have tried tightening the drawbolt on the clutch to the point of stripping the bolt, but no help. Anyone else had to deal with this
BrianThompson
Posted on Friday, February 11, 2005 - 08:35 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Does anyone have information on a Buchanan Marine Motor, F.L. Buchanan Orillia Ltd. Model J4-45 Ser. # 10-400359 Thanks for any help.
curbsidegold
Posted on Tuesday, March 15, 2005 - 10:42 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Problem Solved. The clutch drum is actually in two parts. The inner drum is threaded and forward gear can be adjusted by loosening the drawbolt across the face of the inner drum and screwing it clockwise into the outer drum, then retightening the drawbolt.
