160HP OTTO
Old Marine Engine » Multi Cylinder Gas Inboards » 160HP OTTO « Previous Next »
Moderator
Username: andrew
Post Number: 1066
Posted on Saturday, February 26, 2005 - 05:30 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Larry Healey sent in the following:
quote:
...a scan of the cover of an early magazine of which I have only the copy--it has a 1905 "Otto" marine engine on it that I thought you might enjoy & post it if you wish!
All the best" Larry Healey
otto
pistonring
Posted on Monday, March 21, 2005 - 11:02 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
This is the same engine used in the 1901-1906 submarines. One was built in England, sold to Russia. While being scrapped about 1915 or so it sank in the English channel when under tow. A sub museum in England raised it 15 yrs ago and reported that the engine was not stuck, but the cast iron was crystallized from salt. This is the only one of these known to exist. The same engine was also built in a 2 cylinder vertical version. Made in Phila. PA by Otto.
Thank you,
Dave Reed
Otto Gas Engine Works
2167 Blue Ball Road
Elkton MD 21921-3330
phone 410-398-7340 http://www.pistonrings.net
http://www.pistonring.net
