Volvo md 7b. compression problem.
Old Marine Engine » Diesel Inboards » Volvo md 7b. compression problem. « Previous Next »
markras
Username: markras
Posted on Thursday, June 01, 2017 - 03:49 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Help! My Volvo MD7b had always started first kick - an indicator of good compression, I believe. Recently, the temperature alarm went off. We shut the engine down immediately. So no major damage done. The cause of the overheating was traced to the head. This has been reconditioned. When the head was replaced, the engine refused to start. The mechanic claims that the rings are now no longer holding compression. Given that the engine ran perfectly prior to the repair, this is a bit hard to believe. Can anyone confirm that this is a likely scenario? Basically, he is saying that the top of the engine is now generating too much compression for the bottom of the engine to cope with. Can anyone offer alternative solutions to a rebuild or repower?
j, bradbury
Posted on Friday, March 16, 2018 - 05:03 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
My 8hp Sabb will not start. Just recent decoke,light valve grind, valves set correctly, new exhaust elbow , old one blocked and corroded, injector just been serviced, injector squeeking well , lots of compression, but it just will not fire, it did not even burn a new cigarette. Any ides please?
