'69 Chris-Craft 327Q V-8 intake manif... |
Bruce Decker
| Posted on Thursday, August 19, 2004 - 10:07 am: |
My '69 CC SkiBoat (17 ft fiberglass, in case you would like to know) has a severely cracked intake manifold that has been "repaired" many times, now that I have taken it apart and can see the damage. Any help finding a replacement would be greatly appreciated. The carb base is heavily slanted to accomodate the angle of the installed motor, and the hole for the distributer shaft is located towards the port bow (i.e. front left) of the manifold. The number 822 is cast into the metal. Help! The water skiing season is almost over here in upstate NY! |
gmck62
New member Username: gmck62
Post Number: 1 Registered: 12-2004
| Posted on Wednesday, December 01, 2004 - 07:26 pm: |
Bruce, if you have still not located a manifold , I would need more lnfo to suggest a possable replacement. ie engine manufacturer , hp , cid . some of the old engine builders are no longer in business ,but some of their parts will interchange with newer models |
