detroit sandow icylinder water pump
Old Marine Engine » One and Two Cylinder Gas Inboards » detroit sandow icylinder water pump « Previous Next »
gloman
Posted on Wednesday, December 10, 2003 - 09:11 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
Hello I have a 1 cyl. sandow engine it is missing the water pump that has a three bolt pattern on the side. It is also missing the eccentric on the outside of the crank that drives the bronze connecting rod that goes to the plunger on the missing pump. Funny thing is when I got the engine years ago it had the bronze connecting rod for the pump and none of the water pump except the bottom flange for the water pump it has the same bolt pattern as the bottom connecting point on the side of the engine and so it was bolted to it. I need a picture or a cutaway or some information on specifications to make these parts or if anyone has one laying around to purchase. I also need wiring info on how to hook up the coil and battery to the lever control any and all info wil be greatly appreciated. This type of restoration is new to me but I have been restoring antique tractors and farm machinery for many years and have the equipment to make the part but need info on how the plunger water pump works. thanks to everyone in advance Ed
Richard Day
Posted on Wednesday, December 10, 2003 - 09:19 pm:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I have the castings to make the water pump for the Detroit and I am not sure they are the same for the Detroit Sandow. Got a photo or drawing?
Martin E. McClure
Posted on Sunday, April 03, 2005 - 09:49 am:   Edit Post Delete Post View Post/Check IP Print Post    Move Post (Moderator/Admin Only)
I just bought a Sandow 2 221 Mfg by detroit Motor Car Supply Co. . It has a water pump that I could Photo and send. It is missing all the elec items to provide the spark, any help with this eng or elec. would be appreciated. Marty
Ps any info about the metal boat it came from would be appreciated Wellindavit and Lane And DeGroot Co. 11.3 ft lg, 3.1 beam, Long Island City N.Y. It might have been a life boat or a tender?
