John Kemister
| Posted on Thursday, June 27, 2002 - 10:08 pm: |
Would anyone have information on Vinco marine engines or their maker?I have a 21/2 HP? single two stroke in my 11' 6" clinker launch. The engine was made by Vincent Brothers(1924 - 54?) of Glebe NSW Australia. Engine pamphlets, tech specs and info on the company itself would be appreciated |
mark shannon
New member Username: shannon
Post Number: 1 Registered: 01-2006
| Posted on Friday, February 24, 2006 - 03:46 pm: |
HI LADIES AND GENTS I HAVE JUST AQUIRED A BOAT FOR RESTORATION WHICH HAS A VINCO 21/2HP MOTOR WHICH HAS A RUSTED OUT CYLINDER,ARE THERE PARTS READILY AVAILABLE FOR THESE MOTORS IF SO WHAT IS THE CONTACT INFO OR ANY INFO YOU THINK MIGHT HELP IM ON THE CENTRAL COAST NEW SOUTH WALES I SHALL TRY AND POST SOME PHOTOS.CHEERS MARK |
Tim Mulvey
Post Number: 81 Registered: 05-2003
| Posted on Saturday, February 25, 2006 - 04:51 am: |
The cylinders are no longer available but you could be lucky and find a second hand one with a stationary engine guy as many of these marine enegines were also used to drive pumps and generators in the country hence they survived longer as they are not exposed to salt water corrosion. Try advertising in the Old Machiney Magazine (TOMM) - do a google seach in Australia and you'll readily find their website. |
Evan Roberts
Member Username: robbo
Post Number: 5 Registered: 12-2005
| Posted on Tuesday, May 30, 2006 - 03:28 am: |
Hi All, I have soaked my 2 1/2 hp Vinco in mollasses and diesel for many months and now have it apart - EXCEPT that the piston is well and truly seized. The tip in regard to making up wedges about the conrod is one option the other the tip in regard to a pipe to slide down the cylinder and heat up the head I assume from the outside with oxy. Can anyone provide any further help before I embark on these drastic steps. Regards, Evan |
Peter Ogborne
Post Number: 138 Registered: 09-2002
| Posted on Tuesday, May 30, 2006 - 06:53 pm: |
Evan .....see if you can use a less drastic method . Soak the cylinder in Diesel also auto transmission oil is good . The gently tap the piston with a wooden punch and a reasonably heavy hammer . Get a little move ment and you are winning. |
Frank Seifert
New member Username: powerit096
Post Number: 1 Registered: 05-2008
| Posted on Monday, May 05, 2008 - 07:59 am: |
Hi guys. I'm a first-time poster to the forum. I recently acquired a Vinco two stroke inboard and would like to ask two questions: First, how can I tell whether it is a 2-1/2 or 4HP engine? Also, what is the right spark plug for this engine. It came with a KLG A10 two-piece 7/8" plug. What would the correct Champion plug be for unloaded demos at rallies? (only pumping its own coolant around). I figured something like a 3-com or 20 would be hot enough. Any ideas on this? Many thanks ... Frank |
Todd Vidgen
Member Username: todd_vidgen
Post Number: 29 Registered: 03-2008
| Posted on Monday, May 05, 2008 - 05:59 pm: |
Hi frank ,if its got head studs its the 2 1/2 Bantam If its a solid block then its the 4 Got to go up to the shed to check plug type, Get back to you later today |
Todd Vidgen
Post Number: 30 Registered: 03-2008
| Posted on Monday, May 05, 2008 - 06:07 pm: |
A KLG A10 Crosses over to a Champion W20,NGK dont have a cross reference nor do Bosch |
Eric Schulz
Advanced Member Username: eric_schulz
Post Number: 38 Registered: 01-2007
| Posted on Tuesday, May 06, 2008 - 06:42 pm: |
Todd, do you own a Vinco Bantam? Could you supply a photo please? Eric |
Todd Vidgen
Advanced Member Username: todd_vidgen
Post Number: 31 Registered: 03-2008
| Posted on Tuesday, May 06, 2008 - 07:49 pm: |
Eric ,I will try to get a photo,but it may take a little while as I have to pry the camera off the wife and daughters then get one of them to show me how to put them on this site(first time for everything eh?) |
Stephen Cram
| Posted on Wednesday, July 06, 2011 - 06:37 am: |
Hello, I am new to the forum and would like to know if it is possible to purchase a Vinco engine.It is to replace one that use to be in a boat I am restoring in Sydney. |
